Appleseed 2004 1080p BluRay x264-SADPANDA | Hạt Táo { Sub Việt }
Thảo luận trong 'Blu-ray 1080p' bắt đầu bởi Philong123, 9 Tháng một 2017.
    Hạt Táo
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : High@L4.1
    Format settings, CABAC                   : Yes
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1h 45mn
    Bit rate                                 : 8 869 Kbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 24.000 fps
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.178
    Stream size                              : 6.52 GiB (75%)
    Writing library                          : x264 core 142 r2491 24e4fed
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8869 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Default                                  : Yes
    Forced                                   : No
    Audio #1
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 1h 45mn
    Bit rate mode                            : Constant
    Bit rate                                 : 1 510 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Frame rate                               : 93.750 fps (512 spf)
    Bit depth                                : 24 bits
    Compression mode                         : Lossy
    Stream size                              : 1.11 GiB (13%)
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio #2
    Format                                   : DTS
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 1h 45mn
    Bit depth                                : 24 bits
    Language                                 : Japanese
    Default                                  : No
    Forced                                   : No
    Text #1
    Format                                   : UTF-8
    Codec ID                                 : S_TEXT/UTF8
    Codec ID/Info                            : UTF-8 Plain Text
    Duration                                 : 2mn 22s
    Bit rate                                 : 2 bps
    Count of elements                        : 2
    Stream size                              : 37.0 Bytes (0%)
    Title                                    : forced
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Text #2
    Format                                   : UTF-8
    Duration                                 : 1h 34mn
    Bit rate                                 : 40 bps
    Count of elements                        : 800
    Stream size                              : 28.3 KiB (0%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Trong một xã hội không tưởng được tạo ra vào cuối của cuộc chiến tranh thế giới thứ ba, một nữ chiến binh là những người đã được ngắt từ vùng đất cằn cỗi bắt đầu nhìn thấy các vết nứt trên mặt tiền mới này. Và cộng đồng này đã lên kế hoạch cho phần còn lại của nhân loại?
    Link Fshare.VN:
    https://www.fshare.vn/file/PGX12XA96VL5
    Link 4share.VN:
    http://4share.vn/f/2613151214131f17/Appleseed.2004.1080p.BluRay.x264-SADPANDA.mkv.file
    Subscene
    https://subscene.com/
