Baidu Antivirus 2013
Thảo luận trong 'Anti-Virus' bắt đầu bởi ngbaoha, 23 Tháng tư 2013.
  1. ngbaoha
    ngbaoha V.I.P
    Baidu Antivirus 2013 is the professional antivirus software plus ultrafast cloud security. It is a permanently free and very light but protects your system from various malware such as viruses, adware, spyware, trojans, keyloggers, rootkits and other malicious programs. The program uses the multiple antivirus engine. That means it combines the Baidu Antivirus Engine and Baidu Cloud Security Engine with the Avira Antivirus engine to provide you with complete protection against all online threats. Baidu Antivirus 2013 offers an easy to use interface with several advanced configuration options as well as quarantine of infected files. It also has an extremely small memory footprint, so you can actually work on other applications while it is running in the background on your computer.
    Baidu Antivirus 2013 has an easy to use graphic interface for both, novices and experts, which can easily scan their all computer or single folder they suspect could be infected.
    Also the Baidu Antivirus has such usual features for modern ativirus software as automatic updates, Host Intrusion Prevention System (HIPS), scan reports and more.
    Baidu Antivirus 2013 Features:
    • Free download, free upgrade, and free service
    • 11M installation package
    • 10M system resource consumption ensures a smooth and fast running PC
    • Cloud security rapidly identifies unknown virus
    • Ultrafast response to the latest virus
    • Support for English
    • Independent local virus database detects local virus precisely
    • Intelligently auto choose different engines
    • Precisely detects and removes 99% threats
    • Baidu Antivirus is compatible with 10 mainstream security software perfectly
    Supported Operating Systems: Windows XP, Vista, Windows 7, Windows 8 (32-bit & 64-bit).
    Homepagehttp://sd.baidu.com/
    :ss:
  2. lambanmai8283
    TQ đang căng thẳng thế này chả dám dùng, có khi lại cõng rắn cắn Windows :canthan:
  3. ngbaoha
    ngbaoha V.I.P
    Hết biết dùng gì test thử cái này . Giao diện đẹp đó chứ
  4. lambanmai8283
    Tung kủa thì từ trước tới giờ vẫn được cái mã mà. Chất thì không dám thử, sợ A Tàu lắm, vụ hao123 còn chưa nguội :anhiu:
  5. iSkyfree
    iSkyfree V.I.P
    Baidu là trung tâm của malware, cái phần mềm này cũng không biết có tin tưởng được không :chettui:
    Chỉ thích mỗi cái dịch vụ Cloud của nó thôi :chemgio:
    Mitxitorang and lambanmai8283 like this.
  6. sirhat
    sirhat Member
    Khựa anti virus spam
