Cyborg 1989 1080p Bluray x264-FilmHD | Người Nửa Máy
Thảo luận trong 'Blu-ray 1080p' bắt đầu bởi Philong123, 12 Tháng mười một 2017.
    Người Nửa Máy
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : High@L4.1
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, CABAC                   : Yes
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1 h 26 min
    Bit rate                                 : 8 300 kb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 040 pixels
    Display aspect ratio                     : 1.85:1
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 (24000/1001) FPS
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.173
    Stream size                              : 4.90 GiB (90%)
    Writing library                          : x264 core 125 r2208 d9d2288
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8300 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Codec ID                                 : A_DTS
    Bit rate mode                            : Constant
    Bit rate                                 : 768 kb/s
    Channel(s)                               : 6 channels
    Channel(s)_Original                      : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 93.750 FPS (512 SPF)
    Bit depth                                : 24 bits
    Compression mode                         : Lossy
    Stream size                              : 475 MiB (8%)
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : UTF-8
    Codec ID                                 : S_TEXT/UTF8
    Codec ID/Info                            : UTF-8 Plain Text
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Menu
    00:00:00.000                             : en:00:00:00.000
    00:00:25.192                             : en:00:00:25.192
    00:04:14.087                             : en:00:04:14.087
    00:05:24.699                             : en:00:05:24.699
    00:10:31.881                             : en:00:10:31.881
    00:16:20.479                             : en:00:16:20.479
    00:23:38.167                             : en:00:23:38.167
    00:28:52.814                             : en:00:28:52.814
    00:32:34.077                             : en:00:32:34.077
    00:36:01.076                             : en:00:36:01.076
    00:40:01.482                             : en:00:40:01.482
    00:46:34.917                             : en:00:46:34.917
    00:49:52.364                             : en:00:49:52.364
    00:55:11.725                             : en:00:55:11.725
    00:56:38.103                             : en:00:56:38.103
    00:59:36.615                             : en:00:59:36.615
    01:05:58.037                             : en:01:05:58.037
    01:09:25.036                             : en:01:09:25.036
    01:12:41.566                             : en:01:12:41.566
    01:19:29.723                             : en:01:19:29.723
    01:22:11.802                             : en:01:22:11.802
