SMSCaster E-Marketer GSM Standard v3.6 full key,Phần mềm gửi tin nhắn hàng loạt tới di động trên máy
Thảo luận trong 'Portable Software' bắt đầu bởi ghost0bk, 23 Tháng năm 2013.
  1. ghost0bk
    ghost0bk www.KeyPhanMem.info Staff Member
    [​IMG][​IMG]
    Key Features:
    Convenient: Send & receive SMS right from your computer. Do not relies on an Internet SMS gateway.
    Low cost: No registration, no pre-pay and no need to buy SMS credit before start. Utilize your existing mobile phone.
    Phone book: Manage your contact list for different marketing campaigns into project files, with grouping support. Import existing data from a wide varieties of comma separated value and text file with the “Import Wizard”.
    Send personalized SMS: Send personalized SMS content to each recipient by inserting data from the phone book automatically.
    Unlimited SMS: You can send and receive unlimited number of sms during license period.
    Send in different languages: Support GSM 7-bit and UCS2 Unicode encoding with Auto Encoding Selection. Compose your SMS in many different languages: German, French, Dutch, Greek, Italian, Portuguese, Chinese, Japanese, Korean, Arabic, Cyrillic, etc.
    Responder: Auto reply to incoming SMS for pre-defined keywords and reply messages. (Enterprise Edition Only)
    Details:
    SMSCaster E-Marketer is easy-to-use yet powerful SMS message broadcasting software for e-marketing. It allows you to send marketing & advertising SMS and receive response SMS from the computer.
    If differs from other desktop texting software which relies on an Internet SMS gateway. Instead, use your existing mobile phone, GSM modem or cellular terminal and connect it to the computer. The connection can be done via a USB data cable, serial data cable or Bluetooth COM port.
    Designed with bulk broadcasting in mind, SMSCaster helps you manage your marketing campaigns and send customized messages to your target groups. Since SMS is fast and cost effectiveness, messages like promotion, reminder, alert, special notice or statement are well suited to be delivered by using SMSCaster E-Marketer.
    Phần mềm gửi tin nhắn sms hàng loạt (SMSCaster E-Marketer GSM/CDMA Enterprise v3.6) là một phần mềm hết sức tiện dụng giúp cho người dùng có thể tiếp cận khách hàng 1 cách gần nhất và hiệu quả nhất.
    Bạn muốn chăm sóc khách hàng, bạn muốn gởi tin nhắn SMS đến nhiều người để quảng cáo & mua bán… Phần mềm SMSCaster E-Marketer GSM/CDMA Enterprise v3.6 sẽ giúp bạn làm công việc đó
    Bạn chỉ cần có USB 3G, hoặc điện thoại di động kết nối qua máy vi tính theo chuẩn USB như: Nokia, Sony Ericssion, LG, Samsung…
    Với chu trình hoàn toàn tự động, gởi đi khoảng 1.800 SMS -> 3.000 SMS/1h (tùy thiết bị), nếu muốn bạn có thể gắn nhiều thiết bị cùng một lúc giúp bạn tiết kiệm thời gian hơn.
    Các tính năng chính của phần mềm gửi tin nhắn sms ( SMSCaster E-Marketer GSM/CDMA Enterprise v3.6 ) :
    1. Gửi tin nhắn đến một hoặc nhiều số ĐTDĐ:
    - Nhập từng số điện thoại.
    - Nhập từ file: Excel, text.
    - Lấy số điện thoại từ CSDL khách hàng.
    - Lấy số điện thoại từ Contact của Outlook.
    - Mỗi số điện thoại được tinh chỉnh 5 nội dung gửi khác nhau.
    - Tính năng đặc biệt: Gửi hàng loạt đến tên từng người, từng nội dung khác nhau cùng 1 lúc.
    Các tin nhắn đã gửi được lưu lại cùng với trạng thái gửi thành công hay thất bại.
    Trong lúc gửi có thể Dừng - Thay SIM - và Gửi tiếp. Có thể thêm SDT trong khi đang gửi.
    2. Nhận tin nhắn:
    - Tin nhắn khách hàng gửi đến sẽ được lưu vào INBOX của phần mềm.
    3. Tìm kiếm tin nhắn:
    - Có thể tìm theo nội dung, số điện thoại, thời gian gửi, … của tin nhắn trong INBOX và SENTBOX
    4. Lưu tin nhắn & danh bạ ra file *.xls, *.pdf
    5. Lập lịch gửi tin nhắn
    - Theo ngày, giờ, tuần (gửi cho 1 SĐT hoặc 1 danh sách SĐT)
    - Gửi cho từng SĐT theo các giờ khác nhau, import từ file excel.
    6. Quản lý Danh bạ
    - Thêm/Sửa/Xoá thông tin contact
    - Lưu contact theo nhóm
    - Sắp xếp contact loại thông tin
    - Gửi tin tới 1 nhóm hoặc danh sách contact được chọn
    7. Quản trị hệ thống
    - Quản lý tham số cấu hình thiết bị
    - Quản lý tham số kết nối đến CSDL
    8. Chống tin nhắn SPAM
    - Quản lý danh sách SĐT không nhận tin (blacklist).
    9. Kết nối nhiều modem
    - Kết nối đồng thời nhiều modem, nhận dạng modem & PORT kết nối tự động.
    - Không giới hạn số modem.
    - Kết nối điện thoại di động qua Bluetooth , cáp dữ liệu , cổng USB , cổng COM.
    - USB 3G các mạng (Viettel, Mobifone, Vinaphone).
    10. Hỗ trợ nội dung WAP Push và Tin nhắn Flash
    - WAP push: gửi đường link wap/web đến ĐTDĐ.
    - Tin nhắn Flash: toàn bộ nội dung tin nhắn hiện ngay trên màn hình mobile. Người dùng có thể đọc ngay mà ko phải mở để xem. Khi xem xong tin nhắn tự hủy mà không lưu lại trong Inbox của ĐTDĐ.
  2. mr duc
    mr duc Member
    SAO MINH KO DOAWLOAING DC UNG DUNG NHI
