Xilisoft 2010 PACK - 26 Audio & Video Tools [GÓI 26 PHẦN MỀM CHUYỂN ĐỔI MULTIMEDIA]
Thảo luận trong 'Burning - Converter - Ripper' bắt đầu bởi Kenh24, 14 Tháng tư 2011.
  1. Kenh24
    Kenh24 P.Trưởng C.A Thôn
    I have downloaded all installers from Xilisoft homepage for total safety.
    All folders include Working and tested serials, most of which have been created using Multi-keygen supplied by Team Lz0 (I've registered several copies on my PC before making the torrent).
    Install notes and info are included within each directory and everything has been neatly organized in separate folders.
    Install notes:
    *IMPORTANT tip about Xilisoft products*
    1. Install the program (double click on the exe file).
    2. You MUST block with your firewall the main Xilisoft .exe found in c:\Program Files\Xilisoft\each of the 26 Xilisoft product.
    3. Open Xilisoft > Click on "Help" > click on "Enter registration code" > enter one of the serials to register the application.
    4. Do not update Xilisoft so uncheck the auto updates in those products where this option is available (look in "Preferences")
    Nguồn: viettorrent
  2. bangchuvnn
    bangchuvnn Member
    không có pass unrar
    VTD thích bài này.
  3. vitconvnz
    vitconvnz Member
    Soft này chuyển file là vô địch rùi, chất lượng tốt.
    Đang dùng bản 6.0
  4. Làm ơn chỉ cụ thể hơn phần mềm Xilisoft (Bằng Tiếng Việt)...Tìm hoài không thấy "2. You MUST block with your firewall the main Xilisoft .exe found in c:\Program Files\Xilisoft\each of the 26 Xilisoft product."- do không biết tiếng anh. Thông cảm nhé.
    Có khóa Unrar.
  5. jordan4x
    jordan4x Member
    thank you!!!
  6. ntluat.0k
    ntluat.0k Member
    Anh úp lại cho em cái link mới
